2.4 and WiFi interference
Reply
Old 04-21-2010, 01:57 PM
sideshow
sideshow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 2.4 and WiFi interference
I need some advice and/or real world experiences. We are going to put a high gain, directional antenna at our field so that the computer there will have internet access for our weather station and web cams. I wanted to know if anyone had any experience of WiFi interfering with 2.4 radios, be it Futaba or JR/Spektrum. The antenna would not be pointing across the flying area. It would be parallel to the runway and offset behind the runway about 50 feet. The routers would only use one of the WiFi channels and always be using the same one.
Thanks in advance.
sideshow is offline
Old 04-21-2010, 02:50 PM
Adui
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 2.4 and WiFi interference
If I understand the 2.4 radios correctly, the only issue you could possibly have is signal loss from RF interferance. I do not believe a wifi routers have enough power to cause this unless you flew really close to the router station.
Unfortunately this may be a try it and see issue though, so look for more knowleagable folks on here to chime in. If worst case you have to try it and see then do some range checks with the plane near the wifi antenna first, then a flight test if that passes without any unnecesary people at the site for safety reasons.
Adui is offline
Old 04-21-2010, 04:10 PM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A high gain antenna gathers all of the transmitted energy and points in one direction. If you don't get directly in the beam you wont have any trouble. Even then you are not likely to notice anything. You will just pass trough it so fast it wont do anything.
A high gain antenna does not increase the transmitter power, it just concentrates it in one direction.
I once set my xpS system next to my WIFI antenna to see it interfered. It didn't even know it was there
dirtybird is offline
Old 04-21-2010, 04:29 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What dirtybird said, not likely to cause a problem.
Rodney is offline
Contact Us Archive Advertising Cookie Policy
