Digital 2.4GHz RX : digital and/or analog servos???
Reply
Old 04-24-2010, 12:53 PM
amrharrymac
amrharrymac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Digital 2.4GHz RX : digital and/or analog servos???
Hi All,
I was at the pond the other day and one of the lads told me you can use analog servos with a digital receiver,
it just doesn't work to try a digital servo with an older alalog RX; it will burn out the digital servo circuitry??
Is this true?
He was using a Futuba 2.4 GHz system with a hi-torque analog servo. Is this only a feature of Futuba; I am running Spektrum gear?
Thanks for Your feedback!
Harry
amrharrymac is offline
Old 04-24-2010, 01:05 PM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Digital 2.4GHz RX : digital and/or analog servos???
I have used Analog and Digital servos with both my 2.4 Rx's and with my 72Mhz PPM and PCM Rx's. I am not aware of a problem.
BuschBarber is offline
Old 04-25-2010, 08:25 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mix and match freely.
BarracudaHockey is offline
Old 04-25-2010, 08:53 AM
boex
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you use a Futaba R6008HS/R6014HS rx in high speed mode, you cannot mix digital and analog servos in channels 1 through 6. You'll fry the analog servos.
boex is offline
