Using non-BEC receiver with ESC
Hi Everybody,
I was looking to use a non-BEC receiver with an ESC that supports BEC. I would rather not have to use a second battery for the receiver and servos so I came up with an idea on how to wire it. But I have no clue if it will actually work. I figured I would have smarter minds look at it and see if they think it would work. Basically I want take the Receiver BEC connection and split it between the Battery input and say CH4 (Throttle) on the receiver. Any thoughts would be helpful.
Thanks!
Thanks!
RE: Using non-BEC receiver with ESC
Maybe I am a little confused then. I thought for a BEC receiver it would be that way. but for a non-bec receiver wouldn't I have to make sure I have the 5V line running to the Battery connection on the Receiver? Maybe I just don't understand the difference.
TX
I've got a similar issue; I need to plug two ESCs with BEC to one receiver. So far, they don't like it, and only one will engage.
I'm using a JR R700 receiver, with two Traxxas XL-5 ESCs.
I've tried removing the positive lead from one of the ESC to the receiver, but it doesn't help.
Anyone have any ideas?
edit; never mind, one of my controls wasn't centered; it works fine.
Thanks pilotpete2 . That is good to know. Since I saw Traxxas sell both BEC and non-BEC receivers, I thought there was a difference. But maybe not...
