DX7 questions
Reply
Old 05-06-2010, 03:18 PM
tacx
tacx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DX7 questions
Hi All,
Have a new dx7. Have some questions regarding the TX.
1. What is the TXs safe low voltage level that I should stop flying? The manual doesn't say which I find strange.
2. Does the DX7 have a low voltage warning signal? If it does what is warning level.
3. In regards to the trainer system. The manual, again, is not very detailed. I have a DX5 which I would like to buddy box with. There are three modes to do this. Normal, P-link, and Slave/P-link. The manual states that the Master and Slave must have the same programming. The dx5 is not a programmable TX, yet Spektrum says they will work together. Also, when using the dx7 in trainer mode does the tx have to be set to a blank model. I have a plane that is bound to the dx5 and would like to buddy box that plane with the dx7. What would be the easiest way to do this. The manual for this section is very lacking.
Tom
tacx is offline
Old 05-06-2010, 06:45 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DX7 questions
I forget what the cutoff voltage is because I use a LiPo but yes, its got a low voltage alarm.
If it goes off land immediately.
Its a 9.6 volt battery so when it gets to that level its probably time to throw it on a charger
BarracudaHockey is offline
Old 05-06-2010, 08:18 PM
tacx
tacx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Barracuda, Thanks for the response.
Can anyone help me with question #3
tacx is offline
