Corona 2,4 GHz Module Problem !!!!!
I bought a Corona 2.4Ghz CT8F Module DSS and I have put in a Hitec Prism 7x.
All right. Tx and Rx are connected well and responds well to commands. But .....
The problem is that everything works well, while the Tx batteries are above 10 volts (measured with the display of the radio).
When 10 volt low, you lose the connection between Tx and Rx, and no way of restablecersa, just changing the pack with one that has more than 10 volts. The pack is placed 2000 mA, and 72 Mhz works perfectly up to 9 volts.
Anyone have any idea about this?
I think the battery is not because I have recycled, and charged several times and respond well, keeping the load. Even when placed in the Tx module with the Corona Module, falls on those first volt load and then passes the 9.8 volt, stable, and stays for long.
I've changed for another and the same happens.
Nor is it logical that he can not work with 9.8 volt.
thanks
thanks
