Throttle failsafe on a AR500 Receiver
Reply
Old 05-08-2010, 09:14 AM
scottlaw40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Throttle failsafe on a AR500 Receiver
I have a Spektrum DX5e transmitter and an AR500 receiver. I had to reverse the direction of my carburetor on my Saito 82a to allow for proper servo hookup. Now my throttle works fine innormal mode. Idle is idle and full power isfull (proper servo directions). When Itest thereceiver failsafe mode, the servo works in the wrong direction, throwing full throttle. Ihave tried rebinding several times always making sure the throttle stick on the transmitter is in idle position. No luck. Any ideas?
scottlaw40 is offline
Old 05-08-2010, 04:24 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Throttle failsafe on a AR500 Receiver
Rebinding in the low stick position should set it.
Sure you're binding correctly?
BarracudaHockey is online now
Old 05-09-2010, 02:41 PM
scottlaw40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, Ibelieve Iam. Ihave followed the AR500 instructions. Place throttle in idle setting, turn on receiver, wait for flashing light, turn on transmitter holding the trainer switch in the on position.
Old 05-10-2010, 07:19 AM
nk3t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You do not mentioned inserting the binding plug, waiting for the constant receiver light, or removal of the binding plug before power down. Although it may be obvious to some, these may be steps that you are omitting.
Dave
nk3t is offline
Old 05-10-2010, 12:53 PM
scottlaw40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah, yes. Let me add more. Idid insert binding plug, while receiver is flashing Ipull on transmitter trainer switch and turn on transmitter power. Wait for solid light on receiver. During this time, the receiver throws itself into failsafe mode while throttle stick is in idle. (I am writing this from memory since Iam traveling right now).
Old 06-03-2010, 10:59 AM
laganm21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am having the exact same problem an I am following the book to the T , and still when it hit fail safe it gose WOT any one figured this out yet
laganm21 is offline
