DX7, elevator split?
Reply
Old 05-19-2010, 11:23 AM
lilhachet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DX7, elevator split?
Hi, I have the DX7 radio in my P47 and how do I set up the ele.? Do I use a Y connector , or, right now I have a servo on each side and no where in the book does it cover mixing the two sides??? Thanks, Guy
lilhachet is offline
Old 05-19-2010, 02:12 PM
jerdavis
jerdavis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DX7, elevator split?
Using a Y harness may complicate the mechanical set up of the servos. You may need to use a reversing Y harness to make one of the servos run in the right direction.
Split elevators can be done by using either the flap channel or aux 2 channel as the second elevator.
Using aux 2 as the second elevator channel:use mix program 5 or mix program 6 (so that the trim will work). Mix the elevator with aux 2 with the elevator as the master and aux 2 as slave. Inhibit the aux 2 switch as described on page 38 of users manual. Set second elevator travel and subtrim and with the respective aux 2 page.
Set 2nd elev direction with +% or - % numbers on mix function page.
Jerry
jerdavis is offline
Old 05-19-2010, 02:34 PM
lilhachet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the quick reply Jerry. I will try to do as you discribed.I'm not real good with the different functions of the radio.
Old 05-19-2010, 04:47 PM
codimasta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try thisX-7 Dual Elevators
Go to Mix#5 (Allows use of trim)
Setup: Master Elevator
Slave Aux#2
Rate +100 % +100%
Set Travel adjustments..Elevator & Aux#2, Sub Trim, etc.
codimasta is offline
Old 05-21-2010, 10:14 PM
lilhachet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool,I will try that, seems simple.,lol
Old 07-14-2010, 10:56 PM
N2WATERSPORTS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Horizon rep advised to plug the right side servo into the elevator port and the left side into the AUX 2 port then follow the directions given above.
N2WATERSPORTS is offline
Reply
Display Modes
