Pitch Changes on Throttle Hold on 8U
Reply
Old 07-20-2003, 04:31 PM
shave847
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pitch Changes on Throttle Hold on 8U
Hello,
I am trying to set up to do auto rotations with the throttle hold switch like the book. I really want to do it in normal mode (not Idle1 or 2) due to the way the govenor is set up and the pitch curves I have (see set up below). I get pitch movement when i toggle the hold switch no matter what mode I am in and can't figure out why. It looks like it goes to something like idle 1 or 2 curves but:
in idle 1 or 2 mode the pitch does not change at 100% up or down as throttle hold is toggled. It only moves between these points and always negative going to hold?Why?
What I really want is throttle hold to go to the normal pitch curve (or let me stay in it while its selected) so I get -4 pitch as a minimum) and so govenor knows to be disabled.
Please help.
Additional Info-8U super radio
Throttle curve. I use a GV-1 that operates on stick position in Normal, runs 1550 in idle1 and 1700 in idle 2. This works great.
Normal pitch curve is -4 degrees to 11
Idle 1 and 2 are -11 to 11
I have no hover pitch adjustment in knob or trims set
Use a HH 401 gyro - works great also
shave847 is offline
Old 07-21-2003, 01:03 AM
fritzthecat
fritzthecat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Adjust your Throttle Hold Pitch Curve to match the numbers on your Normal Pitch Curve. TH Hold has it's own unique Pitch Curve.
Fritz
fritzthecat is offline
Old 07-21-2003, 11:43 PM
shave847
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hold Pitch
Thanks that works great.
shave847 is offline
