Rebinding a Spektrun rx with a different radio
RE: Rebinding a Spektrun rx with a different radio
Sure, assuming you mean another Spektrum radio, but it can be bound to only one transmitter at a time. If you want go back and use the receiver with the first radio, you'll have to rebind to that transmitter again.
Pete
Pete
ORIGINAL: pilotpete2
Pete
Pete
When you bind a reciever to a transmitter the receiver is memorizing the GUID (Globally Unique ID) of the transmitter. It stores it in a non-volitale memory buffer. If you have a native 2.4 transmitter (one without a module) then it has model match, that appends the model memory number to the GUID.
When you bind it to different transmitter, or different model memory, then you purge that buffer and it memorizes a new code.
Does that help you understand why it ignores signals from other 2.4 radios and why you have to rebind it if your changing transmitters?
Banned
PA
ORIGINAL: dug44
Yessser, and spektrum will only work with spektrum
