Spektrum AR500 and two ailerons servos
BC, CANADA
Using a AR500 with a Spektrum Fubata 2.4 module can I plug in two ailerons servos or is channel five only for landing gear? On a AR6110e it appears to have a aux1 or channel six? for the second aileron servo?
RE: Spektrum AR500 and two ailerons servos
ORIGINAL: bobferguson Using a AR500 with a Spektrum Fubata 2.4 module can I plug in two ailerons servos or is channel five only for landing gear? On a AR6110e it appears to have a aux1 or channel six? for the second aileron servo?
How to do flaperons using the Spektrum AR500 receiver
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
It all depends on your transmitter. As long as the second aileron channel can be mixed to channel 5 (gear), you should have no problem.
Futaba radios that use a module are almost certain to be able to allow Ail 2 on channel 5, I know my 9C can do it with no issues[8D].
Pete
Pete
