servo jitter when load applied
Reply
Old 07-23-2003, 04:40 AM
AeroD79
AeroD79's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo jitter when load applied
When I put some pressure on the servo (not alot of course)
it starts to jitter. The linkage is straight. the servo is a month old which is the Hs81 MG.
Well this is not good when its on the air..
Any one knows why,.? I tried to loosen the screw a bit if it was too tight but it didnt fix it.
AeroD79 is offline
Old 07-23-2003, 09:31 PM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you putting enough pressure on it to make it try to center? Sounds like it is trying to search for center. They probably all do it if you put enough pressure on them. How much pressure are you applying?
FLYBOY is offline
Old 07-23-2003, 09:57 PM
MHawker
My Feedback: (16)
MHawker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ditto to what Flyboy said. They all "fight" to stay centered.. some better than others. As long as it's just a small vibration, you're fine. If it's chattering back and forth, you should send it in to get checked.
I think I remember something in the instructions with my HS-55's that said something about loosening the CASE screws a bit if the servo hummed or chattered at idle. Take a look at your instructions and see if it has something similar.
MHawker is offline
Old 07-24-2003, 08:01 AM
AeroD79
AeroD79's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its been isolated, when I switched to a newer servo..with the same set up..it stopped..
i htink its just worn out
AeroD79 is offline
Old 07-27-2003, 06:42 PM
Lynx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Probably just the feedback POT going bad, if you replace it the motor is probably still good.
Lynx is offline
