ar500 antenna positioning
MI
Hi All,
I have a ar500 rx going into an electric plane. Multiplex Eaststar. There is not alot of room in the fuselage, so the battery, battery wires, esc, motor wires, and the rx antenna are going to be in tight quarters. Is there any problem I may have with regard to the equipment causing interference with the antenna? If my antenna needs to be away from anything what would cause it the most problems. Or am I worrying about a non issue?
Tom
Read more: http://www.rcuniverse.com/forum/m_98...#ixzz0rbx7FFUH
Tom
