8UAFS Help in Special Prgm.
NE
Can any of your guys help me here?
8Usuper, Glider2FLAP mode for sailplane WITH MOTOR!
I want to use CROW (Butterfly on the THR STICK, AND
Be able to CUT the motor off of the THR stick from a
PMIX switch. Can anyone suggest how to do this?
I am using sw. "A" for Crow ENABLE.
Then, of course Crow gets MORE as the THR is lowered.
BUT (and here is the kicker), I want to be able to
cut the motor OFF so that I am in GLIDE mode(No motor run)
and then use Crow control for Glide path control.
I also COULD set the Motor ESC to the channel 8 KNOB
if I need to.
Please offer a suggestion!
Byron [email protected] :stupid:
if I need to.
NE
I GOT IT! (Self Taught) :-)
OK Guys and gals!
I have figured out how to do this mix
on a 2.7 meter E-Sailplane with 500 watt
motor and 70 amp Speed controller on
10 cells (12.5v), 2400Mah Zapped pack!
Motor on Gear Drive Robbe 4197 3.7:1 ratio
on the tip of an Aveox 1406/2Y.
Revs to max at output shaft 6800 RPM
spooling a 14 X 9.5 Folding Prop drawing
51 amps on High.
Crow (butterfly) called on with "A" switch,
and operated by the THR stick. (Idle is Max Crow.)
Motor is CUT OFF THR stick by "C" switch.
:spinnyeye
Pmix 4 ABK > CH8
+100 max stick, 0% idle
Link Off
Trim Off
Ofst zero
Switch "C" up
(Channel 8 Knob at 4 o'clock)
ESC plugs into Ch8, Batt @ Ch3
51 amps on High.
:spinnyeye
Pmix 4 ABK > CH8
Link Off
Trim Off
Ofst zero
Switch "C" up
