Futaba 8FGA 8 Channel 2.4 radio
OH
I love this radio. I currently have 5 planes on the radio. I have a problem on my Sukhoi. I had to reverse the servo for the throttle... now the throttle is working fine, but the trim is opposite of the stik. Up on the stik is full throttle. Up on the trim is down throttle.... any ideas? I have a 50 CC RCGF has engine on the plane. Great bird !
RE: Futaba 8FGA 8 Channel 2.4 radio
Hi Guitarman52,
By any chance did you change anything in the H/W REVERSE menu, located under the system menu. Make sure everything is NORM, Not sure who he is[&:] but I would check to make sure J3 and T3 are Norm.
I hope this helps. I've got 6 planes on the 8FG, love it
Pete
Pete
FL
ORIGINAL: Guitarman52
Did you try this?
http://www.rcuniverse.com/forum/m_97...tm.htm#9734077
Doug.
One more thing to try before contacting Hobby Services.
Try setting up a new model in the radio and see if you still have the problem. Something may be corrupted in the Sukhoi memory location.
Best of luck,
Pete
Best of luck,
Pete
