servo voltage from esc?
This may be a dum Q. Dealing with nitro planes servos operate off 4.8 or 6 volts depending on what rx battery you use. But on elec planes what voltage is ur servos getting if your using 3 cell lipo threw the speed control?
RE: servo voltage from esc?
ORIGINAL: tonywayne This may be a dum Q. Dealing with nitro planes servos operate off 4.8 or 6 volts depending on what rx battery you use. But on elec planes what voltage is ur servos getting if your using 3 cell lipo threw the speed control?
Note, the voltage output is of less concern than the amperage available.
Most ESC with BEC will handle 3-4 servos with a 2S Lipo but only 2-3 servos with a 3S Lipo pack.
The higher the power pack voltage, the fewer servos that can be handled by the BEC. refer:
Electronic Speed Control - Why BEC and LVC cause most EP RX problems
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Alan,
I am using the A123 battery for receivers and wanting to buy a field charger to run on DC.
Which is the best in your opinion?
Regards
JC (in Texas)
PS If I win the lottery I'd like to move to New Zealand....if they would let me stay.
Regards
JC (in Texas)
ORIGINAL: JCINTEXAS Alan, I am using the A123 battery for receivers and wanting to buy a field charger to run on DC.
Which is the best in your opinion? Regards JC (in Texas) PS If I win the lottery I'd like to move to New Zealand....if they would let me stay.
At present for field charging Lipo & A123 am using HyperionEOS 0606i because it was imo best available and priced right at that the time.
Technology advances since 0606i bought about 2 years ago, providemore choicesnow (suggest pick one which has a data port for upgrades such as most of the EOS series). Not knowing whatis in your locality, examples:
http://www.bantamtek.com/Support.htm
e-STATION 301DX-II NB: Refer to paragraph & picture "How to identify a fake BC8DX" etc.
Firmware Updates For Hyperion EOS Chargers
Regards
Alan T.
