JR Propo (JAPAN) 11x Zero and DSX11
Old 07-17-2010, 09:22 AM
pitstop000
My Feedback: (26)
pitstop000's Avatar
Default JR Propo (JAPAN) 11x Zero and DSX11
JR Propo (JAPAN) 11x Zero and DSX11 (DSMJ 2.4 module and dedicated DSMJ 2.4)
<o></o>
I need a little more info on these 2 radios. I’m looking for English manuals preferably in PDF format.
<o></o>
I have a few questions about some of the features and programming.
<o></o>
Any information that you have would be appreciated.
<o></o>
Really would like to speak with persons that have and are using these radios.
<o></o>
I’m ready to purchase and just need a little more info.
ID:	1469035   Click image for larger version
Old 07-17-2010, 11:02 AM
pilotpete2
pilotpete2's Avatar
Default RE: JR Propo (JAPAN) 11x Zero and DSX11
JR DSM-J systems are not being distributed in North America, or any area where Horizon hobbies is the distributor.
Check Horizons website for the DSM-2 version for this market, I believe the manual is available for download
Pete
Old 07-17-2010, 12:50 PM
BarracudaHockey
BarracudaHockey's Avatar
http://www.horizonhobby.com/Products...0#quickSupport
Manual sucks, radio rocks. What do you want to know?
Old 07-17-2010, 09:26 PM
1bwana1
The software for these two radios is a bit different as well, so what manual there is may not match the 11X Zero perfectly.  Should be good for the DSX11 though.
Old 07-18-2010, 08:39 AM
pitstop000
My Feedback: (26)
pitstop000's Avatar
ORIGINAL: pilotpete2
Pete
Pete,
<o></o>
Not interested in the DSM-2 version! I’m buying DSM-J Full Hopping System from another source.
<o></o>
Full aware what Horizon distributes in their markets.
Old 07-18-2010, 09:10 AM
pitstop000
My Feedback: (26)
pitstop000's Avatar
My Inquiries are not[/b] based on the Horizon/JR version. I’m only interested information on these two particular TX’s with DSM-J.
<o></o>
I’d like to confirm that the 11x Zero (DSM-J module version) has model
Match and that it has the software for Servo Matching to eliminate using Match Boxes.
<o></o>
I know that the DSX11 (DSM-J Dedicated) has both these Feautures.
<o></o>
I’d also like to know if there are any latency numbers available, and if the module based version is considerably slower.
<o></o>
When it comes to the software, what exactly is different between the two?
<o></o>
At this time I still prefer module based TX’s for the flexibility that they offer, but these two features “Model Match” and “Servo Maatching” are important to me.
Thank You
Old 07-18-2010, 12:11 PM
onewasp
pitstop000
Apparently you do NOT care but that radio is not legal in the USA unless it has FCC certification.
To my knowledge it does not !
BTW It is not a "full hopping system" as you state.
Like all the other systems with frequency 'hopping' it is a DSSS with frequency hopping (a hybrid) and was designed for Japan, though some are also in South Africa.
Hope you enjoy paying for the transport back to Japan should you ever find servicing necessary or advisable.
Unless you are headed to Japan and wish to use it there it is a foolish purchase.
BUT, as stated earlier apparently that does not bother you. Nor
does the fact that your AMA insurance would not apply either, check it out!
Even IF you are using only 72MHz modules servicing is still a problem.
Frame rate is 22ms. Total latency depends upon the Rx as well, if you are using the common meaning for latency. If you are using XJet's definition it would include the servos as well.
JR's 2.4 GHz features, including Rx design is controlled by Spektrum USA. That includes DSMJ which is also designed by Spektrum. Simply for the Japanese market.
As with "gray (black actually) market YS engines" -NO service or parts in the USA.
Old 07-18-2010, 01:25 PM
pitstop000
My Feedback: (26)
pitstop000's Avatar
Onewasp, My decision to fly on DSM-J is because it is legal in the US. I have already asked and confirmed this.
Old 07-18-2010, 02:15 PM
onewasp
Well then, you'll be able to furnish the rest of us, probably including Horizon/Spektrum, with the appropriate FCC ID numbers then.
I really tend to doubt that they exist but with the correct FCC ID numbers we all can find the approvals.
How about sharing it/them with us so that we all may see for ourselves.
The pertinent FCC numbers for the X9303 are :
FCC ID BRWDAMTX10;
IC: 6157 A-BRWDAMT
Those are also the numbers for the original DX7 introduced in 2006 so the RF sections have the same FCC numbers and are the same insofar as the FCC is concerned.
The DSMJ will have similar FCC numbers (but not the same) displayed on the Tx/module or it isn't legal in the USA.
I look forward to learning something new here.
Old 07-18-2010, 02:51 PM
pitstop000
My Feedback: (26)
pitstop000's Avatar
Onewasp, I advise you to contact Horizon/Spektrum yourself for the information you seek.
Old 07-18-2010, 02:59 PM
onewasp
I don't spend time feeding dead horses.
Thanks anyway.
Old 07-18-2010, 03:07 PM
pitstop000
My Feedback: (26)
pitstop000's Avatar
Back to my original inquiry,
<o></o>
I’d like to confirm that the 11x Zero (DSM-J module version) has model <o></o>
Match and that it has the software for Servo Matching to eliminate using Match Boxes.<o></o>
<o></o>
I know that the DSX11 (DSM-J Dedicated) has both these Feautures.<o></o>
<o></o>
I’d also like to know if there are any latency numbers available, and if the module based version is considerably slower.<o></o>
<o></o>
When it comes to the software, what exactly is different between the two? <o></o>
<o></o>
Thank You
<o></o>
Old 07-19-2010, 12:00 PM
HunkaJunk
I translated a few pages from Japanese, I saw mention of a 10mw power limit on 2.4 GHZ in Japan.
Pitstop000, I advise you to contact Horizon/Spektrum yourself for the information you seek. They were the ones who supposedly told you it was legal in the US, I am unable to confirm this and I'm not looking anymore.
About the only thing I am confident of is that DSMJ is NOT compatible with DSM or DSM2, I will also note that each country has their own laws regarding the 2.4GHZ band, If you operate something in the USA that is designed for a different set of laws than ours, you would be assuming a lot of liability.
Old 07-19-2010, 06:45 PM
slarty
The module based system will not have Model Match as the module system is only processing standard PPM data.
Old 07-19-2010, 08:37 PM
BarracudaHockey
That was my thought but I heard otherwise in relation to this particular system.
Old 07-19-2010, 08:58 PM
onewasp
I thought that too but remember that the11X uses the older module design rather than the new design created for the 12X.
Based upon occupation I'd have to give an edge to Slarty.
Old 07-20-2010, 04:46 AM
pitstop000
My Feedback: (26)
pitstop000's Avatar
The information that I’m receiving is that as long as you are using the 11 channel module (DSM2/DSMJ JR Version) In the Zero it does have Model Match.
<o></o>
If you use one of the other modules ( FASST, Spektrum DM9, 72mhz,or any that are available that can be used in a JR 9303 then it uses the PPM for processing and no Model Match.) This is the information that I’ve gotten so far.
<o></o>
At this point I’ve decided on the module based TX, I’ll find out more when it arrives. . I’m done speculating.
Old 07-21-2010, 06:27 PM
slarty
Please keep us informed when you receive it and tested it for Model Match.
Old 07-22-2010, 05:51 PM
onewasp
pitstop000
Strongly suggest that you read Greg Hahn's comments on page #142 of the August issue of
"Model Aviation". (AMA mag.)
It deals directly with the problem you are creating or at least supporting.
Your "I’m done speculating" has no bearing on the problem.
Old 07-23-2010, 02:39 AM
Turbotronic
I have both. There is no difference in the hardware, pcb's etc between the 2. The TX RF module has the same FCC ID and is legal as far as the FCC is concerned. The DSMJ has better software and is still DSSS hopping over a number of channels. Re-sync is done on a single DSSS channel making it very reliable and fast to relink.
ORIGINAL: onewasp
pitstop000
Old 07-23-2010, 01:15 PM
pitstop000
My Feedback: (26)
pitstop000's Avatar
ORIGINAL: onewasp
pitstop000
<o></o>
Onewasp ,
<o></o>
My “I’m done speculating” [/b]statement pertains to the “Model Match” [/b]and “Servo Matching[/b]” features of these 2 particular radios.
I will not be baited to where you want to lead this to! You are wasting your breath with Me !
DSMJ 2.4 is Legal[/b] in the US!
Old 07-24-2010, 05:55 PM
onewasp
That is YOUR concern not mine.
Old 07-26-2010, 03:25 AM
Pippin
The 2.4Ghz rules in Japan are more or less the same as the rules the Europeans got. Brussels has introduced the 10mW rule too. DSMJ and other "hopping" systems like FASST or FHSS can be sold in Japan, Europe and most parts of the world.
Old 07-26-2010, 06:04 PM
slarty
ONLY if it has CE certification... (which it hasn't as yet)
Old 07-26-2010, 06:32 PM
CustomPC
CustomPC's Avatar
I'm not from Europe, but i would bet that Spektrum will release DSM-J in Europe before too long.
They've invested $$ in the new DX-10 tray radio which will have a wider acceptance in Europe than it would in the states. If they want to recoup their R&D investment they will have to sell it with a legal RF system.
