Mini-disaster question
My Feedback: (13)
1 Post
Seems I've ruined a 1600 5 cell RX battery and probably a receiver. I am wondering why and seeking explanations. I was setting up an engine test stand which I have done many times. I just needed to set the throttle servo and plugged in the battery directly into the RX battery slot, with no switch in between. Receiver was a Futaba six channel. I've done that many times before, but I don't remember if I was using a 5 cell battery before. The battery immediately shorted, burned my hand, and smoked on a spot on the battery, and melted the connector. I quickly disconnected the battery, but I think the damage has been done. What rules did I violate. What a bonehead!!!
Thanks.............
Thanks.............
SC
RE: Mini-disaster question
The 5 cell battery shouldn't have hurt the RX. I've plugged batteries directly into RXs MANY times while testing servos on the bench. I run 5 cells all the time. No problems. The switch does nothing except open or close the circuit.
For that type of damage to occur, you had a dead short somewhere. Check the RX with another battery - the short may actually be there, since the battery didn't meltdown until you plugged it in.
Good luck.
Good luck.
ORIGINAL: GarySS Seems I've ruined a 1600 5 cell RX battery and probably a receiver. I am wondering why and seeking explanations. I was setting up an engine test stand which I have done many times. I just needed to set the throttle servo and plugged in the battery directly into the RX battery slot, with no switch in between. Receiver was a Futaba six channel. I've done that many times before, but I don't remember if I was using a 5 cell battery before. The battery immediately shorted, burned my hand, and smoked on a spot on the battery, and melted the connector. I quickly disconnected the battery, but I think the damage has been done. What rules did I violate. What a bonehead!!! Thanks.............
However, unlike other brands which have long snipped out the signal pin in the RX battery slot or have a protective diode where necessary, Futaba did not do so until recently. Plugging a battery in with polarity reversed has been known to short out a number of Futaba RX, especially the two channel units used in gliders, cars and boats..
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
My Feedback: (13)
1 Post
It is quite possible I had reversed the plug and it went into the RX. The RX is toast as I noticed the pins for channel 3 are gone. Guess I will be ordering some new equipment. Thanks for the responses.....
TX
Plugging it in backwards shouldn't do any harm. It's a 3 wire plug with power in the center, so if you get it backwards power is still in the center and there's no clear path to ground.
If plugging in a battery backwards would cause a short every receiver in the world would have burned up by now. They are designed to be resistant to errors.
TF
TF
ORIGINAL: rctom Plugging it in backwards shouldn't do any harm. It's a 3 wire plug with power in the center, so if you get it backwards power is still in the center and there's no clear path to ground.
If plugging in a battery backwards would cause a short every receiver in the world would have burned up by now. They are designed to be resistant to errors. TF
Regards
Alan T.
