PCM to FM
PCM to FM
OK I want to upgrade to a PCM 9C or the JR8103 PCM but all my flight packs are Futaba Fm is it easy to switch back and forth or can it?? because I got sticker shock on the price of those PCM RX's for additional flight packs WOW
My Feedback: (7)
PPM and PCM = FM
"OK I want to upgrade to a PCM 9C or the JR8103 PCM "
To clear up some confusion have with your question ?.
The 9C wil work with your exsisting "FM" recievers while in PPM mode, It will not operate them in PCM mode.
Each model Memory can be programed for which ever mode you need .
If you want to use PCM , you will need PCM recievers.
