BASIC: How to set up zaggi delta wing on my dx7?
Having a tough time getting everything to go the right way.
left aleRON IS IN - ELEVATOR ON RECIEVER
RIGHT ALERON IS PLUGGED INTO ALE ON RECIEVER AND THE THROTTLE WORKS.
So what do I need to do, clear this and start?
flaperon is on
vtail off
All channels are in the down area.
No other changes.
How do I set this up? When I pull back the laeft aleron goes up. Right aleron command makes the right aleron only go down. Should be both and the other way.
flaperon is on
vtail off
No other changes.
HI
RE: BASIC: How to set up zaggi delta wing on my dx7?
left aleRON IS IN - ELEVATOR ON RECIEVER RIGHT ALERON IS PLUGGED INTO ALE ON RECIEVER AND THE THROTTLE WORKS.
flaperon is on
vtail off
All channels are in the down area. No other changes.
flaperon is on
vtail off
L. Aile - Aile channel
R. Aile - Elev channel
Wing type - Delta
You may need to reverse one or both channels to get the correct movements.
Let me know if this helps, if not I can post my actual settings when my TXisn't being charged.
ALoha,
Les
ORIGINAL: molokaiboy
My TX is being charged, but I believe you plug in as follows:
Wing type - Delta
Let me know if this helps, if not I can post my actual settings when my TX isn't being charged.
ALoha,
Les
flaperon is on
vtail off
flaperon is on
vtail off
Wing type - Delta
ALoha,
Les
