Futaba to JR Servo Adaptors
Is there an adaptor to connect old type Futaba servos to JR 700 receiver? My Futaba servos have the exposed male prongs 90 degrees from the wires. I need either an adaptor to plug into the JR receiver into which I can plug the Futaba servo plug, or a servo cable with the JR plug on one end and the Futaba female receptacle on the other end. If either of these are available where might I find them ? Thanks in advance.
RE: Futaba to JR Servo Adaptors
If it were me I'd just either cut the old connectors off and crimp new ones on, or I'd just cut the wires and solder on new extensions. I often lengthen my servo extensions by cutting the plugs off and just soldering new extensions on so I do this all the time. It's not good practice to introduce more connectors such as adapters into the circuit. They just cause voltage drops and introduce another point of failure.
Thanks Joe, sounds like a good solution. Do you know if I can change a 72.080 MHZ Futaba transmitter and receiver to a legal FM frequency by changing crystals?
ORIGINAL: lleach1 Do you know if I can change a 72.080 MHZ Futaba transmitter and receiver to a legal FM frequency by changing crystals? |
ORIGINAL: lleach1 Thanks Joe, sounds like a good solution. Do you know if I can change a 72.080 MHZ Futaba transmitter and receiver to a legal FM frequency by changing crystals? The suggestion of sending the system to Radio South is a good one. They are about the only folks still doing conversions. Steve |
Depending on what transmitter and receiver you have, it may not make sense to spend any money having it modified.
ORIGINAL: carrellh Depending on what transmitter and receiver you have, it may not make sense to spend any money having it modified. I've got an older Futaba 6FG that's a great radio.. narrow band and all... but I can't even justify $40 for the required transmitter battery.... part of the reason is I now have ONE transmitter that operates everything.... and that makes it hard to upgrade something thats 20yrs old... not to mention the features on a current radio absolutely blow away anything from 20yrs ago. Most any radio that would need narrow banding, also would need new batteries.. unless you've done that already... but with all the issues of "servo adapters" or new servo-leads..(those aren't cheap by any means either), plus the knowledge/skill to make it all work... you just might be better off(or your planes will be) by thinking about a new radio set. Just food for thought. You might share exactly what you have radio/flight-pack wise, and where your at with it, as there's alot of experience on these boards, and I'm sure in this thread alone that would be more then happy to steer you in the right direction, and possibly SAVE you some money and trouble in the long run. :) |
Thanks guys for all the input. The systems are enroute to Radio South. I have three modern 2.4 gig JR systems with 6 flight packs which are my daily flyers. The old radios have a very personal and emotional importance to me so I am willing to spend the money to have these up and running in the aircraft in which they were installed 31 years ago. All the advice is sincerely appreciated. I think this venue is a tremendous asset for RC enthusiasts of all ages and skill levels. Thanks
ORIGINAL: lleach1 The old radios have a very personal and emotional importance to me so I am willing to spend the money to have these up and running in the aircraft in which they were installed 31 years ago. |
I used to have a mixture of servos with Futaba J connectors and JR connectors because I had both Futaba and JR transmitters and receivers. I found it easier to buy Universal Connectors from Maxx Products (MPI). In this way, I did not have cut and splice wires. The MPI Universal Connectors have a Futaba Female connector and a JR Male connector.
www.radicalrc.com sells connector kits that will enable you to cut off the old Futaba style and crimp on new JR style.
....or you could take a pocket-knife and carve off the little tab on a Futaba plug. It takes ten seconds, free, requires no extra equipment, and works just as well.
Carving off the tab works in some instances. You also need to bevel the corners, as well, or it will fit too tightly in the JR female connector. This is especially true if you are going to use these connectors in Spektrum Rx's, which have a very tight tolerance.
I believe he's talking about the much older Futaba servo connectors with the pale pins protruding from the body.
Newer (current) ones actually have female connectors inside the housing, even though they call it a male - they're referring to the plastic body. You can't trim a tab and shave corners to make those old ones work - cut 'em off and put new connectors on is probably the best way. |
ORIGINAL: fizzwater2 I believe he's talking about the much older Futaba servo connectors with the pale pins protruding from the body. Newer (current) ones actually have female connectors inside the housing, even though they call it a male - they're referring to the plastic body. You can't trim a tab and shave corners to make those old ones work - cut 'em off and put new connectors on is probably the best way. My bad, comment retracted! <br type="_moz" /> |
