Servos
RE: Servos
Of course.
RE: Servos
ORIGINAL: Mo-jim Need help,Can I run standard and didital servos on the same A/C? Thanks MO-Jim [email protected] Also note that many digitals require thicker extension leads and check the servo specification for operating voltages. A few analogue are 4.8v only, most are 4.8v - 6.0v whilst many of the new digitals are HV = 6.0< 8.4v and mixing low with high voltage servos orto low a voltagewill cause problems. Servo - Operating Voltage Range - usuage with Lipol & A123 batteries. See also sub Sections "Glitches & Jitter in Receiver, Servo & ESC - causes and cures " under "Radio Systems, Accessories, Alterations and FAQ."and "Servo - Alterations, Calculators, Databases, Leads, Repairsetc," at: Alan's Hobby, Model & RC FAQ Web Links</p> Regards Alan T. </p> |
