14MZ question
Hi, I am wondering if its possible to be able to get data from a 14mz and see it on a mac or pc. For example, I have an extra 300 programmed on it, is there a way I can see all my inputted values on a computer screen and take a print out? It would be very helpful to get an overal view of all the setup parameters.
thanks<br type="_moz" /> |
RE: 14MZ question
I do not have a 14MZ, but perhaps this will steer you in the right direction.
http://www.rcgroups.com/forums/showthread.php?t=364328 The JR 9303 and above has a PC Data Transfer Program that allows you to Coy Model Memories to a PC, Edit them, Print them out, Copy them back to the same or different Tx, and even email them to a friend. Since Futaba uses SD cards, perhaps there is software that allows you to do similar things. |
