Airtonics RX and Hitec Servos Help????
Will Hitec servos that were used with a futaba RX work with an airtronics RX. The airtronics RX is preety new and has Z connections. The servos are also new. If plugs are different are adapters made and how much? Please help im a newbie:'
You may have to cut the tab of but they should plug in after that, and you may have to round the corners too.
Dru. |
So the only reason they wont work is because of the phyiscal difference in the connector tabs? The Wires are in the same order on the plug tab?
Adam Your right as long as it is the newer Airtronic Z con. Just trim away. I do it all the time .
thanks for they help guys. Im planning on buying a plane that had a futaba RX with hitec servos, I wanted to make sure i didnt have to buy more equipment.
Hitec does not make a Futaba type plug so the Hitec servos will fit the newer Z connector Rx's without the need to trim anything its only the Futaba type plugs that need trimming to fit JR, Airtronics Rx's. To simplify this matter the JR, Hitec and Airtronics Z plug are the same in shape and wiring. The Futaba plug has a similar shape but needs a tab cut off and a little bit of material removed from the sides to then be of the same shape as the other plugs. The Futaba plugs are also wired the same way.
