RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Radios, Transmitters, Receivers, Servos, gyros (http://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   someone bind 6J to Tactic RX please (http://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/10784186-someone-bind-6j-tactic-rx-please.html)
guver 10-26-2011 04:34 PM
If someone has them would you please bind the Futaba 6J , 8J or even the 4YF TX to any Tactic 2.4 RX? I'll greatly appreciate it before I order my own. Thanks.
ton2di 10-26-2011 04:46 PM
RE: someone bind 6J to Tactic RX please
I just bought a T6J. Do you have any tactic rx to test?
guver 10-26-2011 04:51 PM
Sure, could I send you one? You can keep it. If so pm me your ship address. I'll just want to know if it binds and if you could use it (test it out at range) for me that would be great. If it works I'm going to buy a 6J for myself.
I'm not seeing a T6J , what is the T?
ton2di 10-26-2011 04:59 PM
It is just the designation for the Futaba TX's. i.e. T7C, T6ex, T6J etc. I will pm you my address then I'll just return your rx after.
TimBle 10-26-2011 09:05 PM
not sure a Tactic binds to Futaba....
Silent-AV8R 10-26-2011 09:25 PM
Tactic and Futaba are not compatible. Each only works with their own brand. In addition, the Futaba 6J and new 8J only work with the S-FHSS receivers. They will not work with the FASST receivers.
guver 10-27-2011 01:37 PM
Quote:
ORIGINAL: Silent-AV8R
If you know this for sure it will save me some shipping and a lot of wasted time for ton2di. These Tactic RX are FHSS , I am not sure what the "S" is but the Futaba TX are supposed to do both FHSS and S-FHSS , right?
Silent-AV8R 10-27-2011 02:01 PM
Quote:
ORIGINAL: guver
If you know this for sure it will save me some shipping and a lot of wasted time for ton2di. These Tactic RX are FHSS , I am not sure what the ''S'' is but the Futaba TX are supposed to do both FHSS and S-FHSS , right?
I know it "for sure". But why not ask your question the in Vendors only area and one of the Futaba support people can confirm it for you.
This might help too:
http://www.rcuniverse.com/forum/m_10770180/tm.htm
guver 10-27-2011 05:01 PM
I know what Krysta said. A hobbico Rep said that the 4YF MAY be compatible. It's probably like many things in life , just do it yourself to see.
TimBle 10-27-2011 08:32 PM
tell us how it works out for you. Maybe you onto something...
Silent-AV8R 10-27-2011 10:09 PM
Quote:
ORIGINAL: guver
Not sure who your unnamed "Hobbico rep" is, but you do realize who Krysta is, don't you? Hint - she works for Hobbico.
Skaluf 10-28-2011 05:29 AM
Tactic and and Futaba are not compatible. They will not link to each other.
Steve
Silent-AV8R 10-28-2011 05:43 AM
Quote:
ORIGINAL: Skaluf
Steve
OK, Krysta, Steve, and Bill B. have ALL said that the two systems are not compatible. They ALL work for Hobbico. I think that pretty much seals the deal for me!!
Krysta 10-28-2011 05:51 AM
You of course are welcome to try, but Tactic is not made by Futaba and these two are not compatible.
I am sorry you received incorrect information from a Rep when you called Hobbico. But in the future, if you have questions directly related to Futaba items, you may want to contact the Futaba Support line directly at 217-398-8970 opt 2, by email at support@futaba-rc.com or by fax at 217-398-7721.
Also Bax and I are available here in the Futaba Support forum. And yes, I do work for Hobbico and have for over 20 years.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
service@futaba-rc.com
Quote:
ORIGINAL: guver
Dick T. 10-28-2011 08:58 AM
Quote:
ORIGINAL: Krysta
Sincerely,
Krysta
Krysta, Hobbico must have used child labor then since you are only 32 years old now!!
Krysta 10-28-2011 09:46 AM
How did you know??? LOL
Krysta
[/quote]
[/quote]
guver 11-14-2011 04:25 PM
How'd I miss all these responses? Anyways thanks guys. ton2di did indeed try it for me and it didn't work , of course. Thanks ton2di and others. I suppose I need to wait until Tactic make a TX with model memory.
TimBle 11-14-2011 10:27 PM
probably not going to happen. Tactic is a Hobbico brand. The Tx with model memory is the T6J by Futaba.
TimBle 11-14-2011 10:43 PM
guver 01-14-2012 01:19 PM
I e-mailed them. Tactic has stated that they do not and will not (soon) make a TX with multi-model memory. The any-link may be the better alternative http://www.tacticrc.com/tacj2000.html
Hopefully it will allow me to use a TX with all of my Tactic Rx in my planes. I plan to try it out on the Turnigy 9x even though it isn't on the list. This should allow many users the same alternative.
