9c
Can someone please explain in a simple way to get spoilerons to work automatically, say controlled by a switch on the 9C. I have flaperons enabled using channel 6 for flaps but have yet to figure out the spoileron thing. I haven't had the radio very long and some of the programming is kinda confusing.
9c
I use channel 1 and 7, the differential setup instead of the flaperons, and then setup the spoilers on the air brake menu, you can adjust them up or down, etc, mix with elevator, but it only works on switch C. Hope this helps
9c
If you have the flaperons enabled, go to the AUX-CH function on the BASIC-ACRO screen and change the switch for Flaps to a 3-position or a know/slider. On a 3-position, the middle position is neutral up is flaps and down is spoilers (or vise-versa depending on setup).
My flaperons/spoilerons are on VrD (Left slider). It beeps when I hit center (neutral) and if I pull it back, I get spoilerons and if I push it forward I get flaperons. |
