T6xa and U-Can-Do
Whew, boy, am I lost. Been trying to figure out which servo extentions and Y harnesses I am going to need for my U-Can-Do .60 that I have on order. I am going to be using a Futaba T6xa with the PCM reciever. Everytime I read which ones I need it seems to counter-advise itself. Went to my field today and asked around. One suggested I would need
1- Reversing "y" harness 3- 24" extentions 2- 12" extentions I just keep confusing myself the more I think about it. Not even sure that I need a reversing Y Harness since this is a computer radio. Please help!!! |
T6xa and U-Can-Do
You will need a reversing Y because your radio doesnt support dual elevator servos.
All the reversing Y does is changes the direction of one servo thats plugged into it. Easy to use and works pretty well.. |
T6xa and U-Can-Do
I am sorry for being so stupid about this. But please confirm that the following will work.
Aileron: 1- 20" Y harness Rudder: 1- 24" servo extension Elevator: 1- Reversing "Y" connector 2- 24" servo extensions One thing I don't understand is how my Aileron's will go in opposite directions without a servo reversing Harness there also.. Unless each aileron servo has its own channel. And, why do I want my elevator to go in opposite directions? Whew,, I know this is all so simple but for some reason just isn't taking hold in my head. |
T6xa and U-Can-Do
As far as the length of the extensions.... I am not sure.
The reason for the reverser is because your elevators arms will either point up or both down. If you just hook a normal Y to them one will swing forward while one is swinging aft. The reverser makes them both go in the same direction. A normal Y on the ailerons is ok because the arms need to go in opposite directions. One ail up one down.. The reason they go in oppsosite directions is because the arms are on different sides of the servos from eachother. |
T6xa and U-Can-Do
Thank you so much wgeffon. I think I understand now. I knew there was a easy answer. Some times I get things stuck in my head and cannot see my way out. I know I just set myself up for some sort of bashing with that comment but I think I deserve it. ;) . Hmm, you know, just thought of something. I was out at the field today and saw a guy with a Ucando and he could make either side of his elevator go in opposite directions. Will this be possible with this setup? Not that I need to though.
T6xa and U-Can-Do
Not with the T6XAS..
Most computer radios have a way to make dual elevator servos work in a mix but the 6XAS doesnt. I have a 6XAS also and I really like it but it becomes limiting very fast with set-ups like yours. |
T6xa and U-Can-Do
************************* ************************* I would use extensions over a Y for the Ailerons.... I believe the T6XA can still utilize Flaps Spoilers/air brake etc etc......... I have a UCD and you will want the extras........ ;) |
T6xa and U-Can-Do
By using two extentions rather than a "Y",, my ailerons will be on two channels?
T6xa and U-Can-Do
Yes you can do that with the 6XAS.
Left side in Ch1 right side in Ch6 You'll then need to activate FLPPR. This gives you the option for mixing as stated above. I tried all the mixing on my UCD (flapperons, spoilerons etc) and I found it flew better without any. |
T6xa and U-Can-Do
Wayne is right. Forget the Y harness on ailerons since you have a 6 channel radio. Use channel 1 and 6 for your ailerons and activate the flaperon function as outlined in the manual. This has numerous advantages over the Y harness..... such as indivual end point adjustment and centering. You are using TWO aileron servos on the UCD so you might as well use the technology that is available to you with the 6XA.
Ernie |
T6xa and U-Can-Do
Great!! I think I actually understand.. Yes!! It is possible!! It really happened!! Please don't get used to it though. I am the reason for which knowledge-bases were invented. Now I am just waiting for my plane to arrive tomorrow so that I can put it together and crash it. :stupid:
