RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Radios, Transmitters, Receivers, Servos, gyros (http://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Parkzone PKZ1060 3-wire servo with OrangeRX FASST? (http://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/10980618-parkzone-pkz1060-3-wire-servo-orangerx-fasst.html)
g725s 02-28-2012 05:04 PM
Would I have any troubles using these servos with an
OrangeRx Futaba FASST 2.4Ghz Compatible 8Ch receiver?
Specs on the receiver are:
8 Channels
Twin antenna for diversity and long range.
Input voltage: 4~9.8V
Specified Range: 1.5km+
Resolution: 3072
Latency: 22ms
Failsafe
I cannot find specs for the servo, only this page:http://www.parkzone.com/Products/Def...ProdID=PKZ1060
It is the servo that comes stock in the Radian
This is what Ihave:
Futaba 6EX 2.4GHz Transmitter
OrangeRX 2.4GHz FASST Compatible Receiver
Eflite 30 Amp Pro SB Brushless ESC
Two Parkzone PKZ 1060 servos
1300mAh 25C 11.1V LiPo Battery
dasintex 02-28-2012 05:13 PM
RE: Parkzone PKZ1060 3-wire servo with OrangeRX FASST?
Others may chime in; However, I believe that servo is probably a standard servo, therefore it should work without any problems.
g725s 02-28-2012 05:32 PM
<![if gte mso 9]><xml><o:officedocumentsettings><o:targetscreensiz e></o:targetscreensize></o:officedocumentsettings></xml><xml><w:worddocument><w:browserlevel></w:browserlevel><m:mathpr><m:mathfont m:val="Cambria Math"></m:mathfont><m:brkbin m:val="before"></m:brkbin><m:brkbinsub m:val=""></m:brkbinsub><m:smallfrac m:val="off"></m:smallfrac><m:dispdef></m:dispdef><m:lmargin m:val="0"></m:lmargin><m:rmargin m:val="0"></m:rmargin><m:defjc m:val="centerGroup"></m:defjc><m:wrapindent m:val="1440"></m:wrapindent><m:intlim m:val="subSup"></m:intlim><m:narylim m:val="undOvr"></m:narylim></m:mathpr></w:worddocument></xml><![endif][if gte mso 9]><xml><w:latentstyles deflockedstate="false" defunhidewhenused="true" defsemihidden="true" defqformat="false" defpriority="99" latentstylecount="267"><w:lsdexception locked="false" priority="0" semihidden="false" unhidewhenused="false" qformat="true" name="Normal"></w:lsdexception><w:lsdexception locked="false" priority="9" semihidden="false" unhidewhenused="false" qformat="true" name="heading 1"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 2"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 3"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 4"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 5"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 6"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 7"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 8"></w:lsdexception><w:lsdexception locked="false" priority="9" qformat="true" name="heading 9"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 1"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 2"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 3"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 4"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 5"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 6"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 7"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 8"></w:lsdexception><w:lsdexception locked="false" priority="39" name="toc 9"></w:lsdexception><w:lsdexception locked="false" priority="35" qformat="true" name="caption"></w:lsdexception><w:lsdexception locked="false" priority="10" semihidden="false" unhidewhenused="false" qformat="true" name="Title"></w:lsdexception><w:lsdexception locked="false" priority="0" name="Default Paragraph Font"></w:lsdexception><w:lsdexception locked="false" priority="11" semihidden="false" unhidewhenused="false" qformat="true" name="Subtitle"></w:lsdexception><w:lsdexception locked="false" priority="22" semihidden="false" unhidewhenused="false" qformat="true" name="Strong"></w:lsdexception><w:lsdexception locked="false" priority="20" semihidden="false" unhidewhenused="false" qformat="true" name="Emphasis"></w:lsdexception><w:lsdexception locked="false" priority="59" semihidden="false" unhidewhenused="false" name="Table Grid"></w:lsdexception><w:lsdexception locked="false" unhidewhenused="false" name="Placeholder Text"></w:lsdexception><w:lsdexception locked="false" priority="1" semihidden="false" unhidewhenused="false" qformat="true" name="No Spacing"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1 Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2 Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1 Accent 1"></w:lsdexception><w:lsdexception locked="false" unhidewhenused="false" name="Revision"></w:lsdexception><w:lsdexception locked="false" priority="34" semihidden="false" unhidewhenused="false" qformat="true" name="List Paragraph"></w:lsdexception><w:lsdexception locked="false" priority="29" semihidden="false" unhidewhenused="false" qformat="true" name="Quote"></w:lsdexception><w:lsdexception locked="false" priority="30" semihidden="false" unhidewhenused="false" qformat="true" name="Intense Quote"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2 Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1 Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2 Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3 Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid Accent 1"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3 Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid Accent 2"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3 Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid Accent 3"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3 Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid Accent 4"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3 Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid Accent 5"></w:lsdexception><w:lsdexception locked="false" priority="60" semihidden="false" unhidewhenused="false" name="Light Shading Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="61" semihidden="false" unhidewhenused="false" name="Light List Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="62" semihidden="false" unhidewhenused="false" name="Light Grid Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="63" semihidden="false" unhidewhenused="false" name="Medium Shading 1 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="64" semihidden="false" unhidewhenused="false" name="Medium Shading 2 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="65" semihidden="false" unhidewhenused="false" name="Medium List 1 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="66" semihidden="false" unhidewhenused="false" name="Medium List 2 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="67" semihidden="false" unhidewhenused="false" name="Medium Grid 1 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="68" semihidden="false" unhidewhenused="false" name="Medium Grid 2 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="69" semihidden="false" unhidewhenused="false" name="Medium Grid 3 Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="70" semihidden="false" unhidewhenused="false" name="Dark List Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="71" semihidden="false" unhidewhenused="false" name="Colorful Shading Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="72" semihidden="false" unhidewhenused="false" name="Colorful List Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="73" semihidden="false" unhidewhenused="false" name="Colorful Grid Accent 6"></w:lsdexception><w:lsdexception locked="false" priority="19" semihidden="false" unhidewhenused="false" qformat="true" name="Subtle Emphasis"></w:lsdexception><w:lsdexception locked="false" priority="21" semihidden="false" unhidewhenused="false" qformat="true" name="Intense Emphasis"></w:lsdexception><w:lsdexception locked="false" priority="31" semihidden="false" unhidewhenused="false" qformat="true" name="Subtle Reference"></w:lsdexception><w:lsdexception locked="false" priority="32" semihidden="false" unhidewhenused="false" qformat="true" name="Intense Reference"></w:lsdexception><w:lsdexception locked="false" priority="33" semihidden="false" unhidewhenused="false" qformat="true" name="Book Title"></w:lsdexception><w:lsdexception locked="false" priority="37" name="Bibliography"></w:lsdexception><w:lsdexception locked="false" priority="39" qformat="true" name="TOC Heading"></w:lsdexception></w:latentstyles></xml><![endif][if gte mso 10]><style type="text/css"> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-priority:99;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman","serif";}</style><![endif]><p style="background:white" class="MsoNormal"><span style="color: rgb(0, 0, 0);"><span lang="NL" style="font-size: 9pt; font-family: ">Warning: HS Mode is only applied for high-speed digital servos. Other servos should select FS Mode, otherwise servos will get heat or even burn out.</span></span><span lang="NL" style="font-size:9.0pt;font-family:">
<span style="color: rgb(0, 0, 0);">This is written in the instructions by FrSky for the OrangeRX receiver.
I would venture to guess that these servos are not high-speed digital servos, does anyone know? Are these analog servos?</span>
</span></p>
chuckk2 02-29-2012 10:07 PM
At the price point, the servos are very likely to be analog. Although not with these specific servos, my experience with similar servos in RTF planes has been that they may have lower resolution than a typical "standard" servo. Fewer "steps", if you will.
