which servo tester to get......
I am thinking about getting a servo tester. I've never used one before, really never thought I needed one and still don't. I've always just plugged my servos into the receiver and adjusted with the transmitter. But, I was thinking about getting one and have found many different types available.
Most of my servos are Hitec 425BB, Jr sport, futaba 3003, and a few micro. All are analog. What are some of the advantages of having a tester? Frank |
RE: which servo tester to get......
ORIGINAL: countilaw I am thinking about getting a servo tester. I've never used one before, really never thought I needed one and still don't. I've always just plugged my servos into the receiver and adjusted with the transmitter. But, I was thinking about getting one and have found many different types available. Most of my servos are Hitec 425BB, Jr sport, futaba 3003, and a few micro. All are analog. What are some of the advantages of having a tester? Frank Manual (via a knob) Auto Exercize Neutral The Neutral is nice because you can connect up to 3 servos, set the Tester to Neutral, and all the servos go to Neutral. You can then center the Servo Arms and then install in the aircraft. It requires a 4.8v or 6v battery. You can also connect an ESC to it just to test it's operation. |
Is there anything other than Hobby King. I just do not trust dealing with them. I've heard too many horror stories of getting items that don't work, terrible shipping times and absolutely no customer service. There has to be another provider.
What are the advantages of using a servo tester? Is it really better than just hooking your servo to the receiver and using the Tx. Frank |
The best servo tester is the GWS. It has a pulse width readout. It also has seven functions including an optical tachometer. You can also hook it up to your receiver and see what signal the transmitter is putting out on each channel. Anyone who is serious about R/C should have a servo tester. I have bought lots of stuff from Hobby King and have never had a problem. Just don't buy LiPo batteries from overseas because they can't be shipped by air. There are other, simpler servo testers but they don't have the features of the GWS. FMA makes a servo tester with a pulse width readout, but it does not have a dial for the pulse width control. It uses buttons to adjust the pulse width. I have one but I seldom use it since the GWS tester is better (and cheaper). The simplest testers just have a dial. They're good for just testing servos and ESCs, but they don't provide any data.
Just following up on that servo tester. Here it is from Hobby King: http://www.hobbyking.com/hobbyking/s...to_select.html
It's also available from BP Hobbies (in US):http://www.bphobbies.com/view.asp?id...7&pid=D0736126 But both places are currently out of stock. |
Have had 2 of the "Turnigy" servo centerers/testers and they are useless. I replaced the first because i thought it was a bad one, it wasnt they are all bad. Basically plug in servo and center it, contect push rod, then when you go to bind RX all servo's arent centered? Its okay to test but dont use it to center.
ORIGINAL: countilaw I am thinking about getting a servo tester. I've never used one before, really never thought I needed one and still don't. I've always just plugged my servos into the receiver and adjusted with the transmitter. But, I was thinking about getting one and have found many different types available. Most of my servos are Hitec 425BB, Jr sport, futaba 3003, and a few micro. All are analog. What are some of the advantages of having a tester? Frank why do you feel you need one? |
ORIGINAL: Herbs_007 Have had 2 of the ''Turnigy'' servo centerers/testers and they are useless. I replaced the first because i thought it was a bad one, it wasnt they are all bad. Basically plug in servo and center it, contect push rod, then when you go to bind RX all servo's arent centered? Its okay to test but dont use it to center. |
The JR Matchmaker -is my favorite- it has an indent in the operating wheel for center - and this does match the rx center positioning.
so you can match /center a pair of servos OR cycle at various speeds two servos any of my JR/Spektrum stuff -or HiTech makes setup much easier i use it with 4.8/7volt setups |
I've used the ServoXciter for years.
http://www.vexacontrol.com/ May be a little expensive, but American made and they give fantastic after-sale service. This one reads pulsewidth out of your receiver and tests your servo current and deadband. IMHO, it's a must for complex aircraft with critical setups, like pattern planes and helicopters. |
ORIGINAL: exeter_acres ORIGINAL: countilaw I am thinking about getting a servo tester. I've never used one before, really never thought I needed one and still don't. I've always just plugged my servos into the receiver and adjusted with the transmitter. But, I was thinking about getting one and have found many different types available. Most of my servos are Hitec 425BB, Jr sport, futaba 3003, and a few micro. All are analog. What are some of the advantages of having a tester? Frank why do you feel you need one? I don't really feel like I need one. But I was curious about the advantages of using one. Frank |
Vexa works great !
