Futaba 6EZ-2.4 Question
What is the best way to set up the trhottle on a Futaba 6EX-2.4 radio on the throttle channel. I have a gas engine and want the throttle response to match the stick movement to the RPM of the engine. Like more gradual on lower end and have full stick at full RPM...not same as carb plate at full travel? Can some ideas be placed here? Thanks
RE: Futaba 6EZ-2.4 Question
Sending you an e-mail re your query.
Karol |
ORIGINAL: karolh Sending you an e-mail re your query. Karol |
ORIGINAL: captinjohn ORIGINAL: karolh Sending you an e-mail re your query. Karol Karol |
I was doing some final triming on the RX....and must have bumped the wrong input. NOW I HAVE THE AILERONS & ELEVATOR MIXED TOGETHER SOMEHOW !!!! How do Iundo this???? As you can tell...computer radio programing is not my thing. Man I had everything working ok ...then the MIX showed up?
I got TX working the controls right now. I had to Inhibit every possible mix. Not fun !
