another 7C question...antenae?
Just bought a brand new Futaba 7C radio.The transmitter antenae is smaller/shorter and girth is smaller compared to some others/older 7C's i've seen at the field.What's up with that?Any body have an answer?
RE: another 7C question...antenae?
The obvious answer is because they put a different antenna on it at some point in the manufacturing process.
Does it really matter as long as it works? :) |
well i don't know...i haven't flown it yet....
If you're that curious you could always ask Bill and Krysta in the Futaba Direct Support forum but things like that get updated or changed over time as suppliers change so I wouldn't sweat it. The actual antenna for a 2.4 system isn't but 2.5cm, the rest of that is just a casing to get it a little higher and away from the rest of the electronics.
