9C/9CAP
I see many references to both 9C and 9CAP radios. Are these two different radios or do some folks simply drop the "AP" in the designation?
RE: 9C/9CAP
ORIGINAL: JollyPopper<span style="font-size: smaller"> I see many references to both 9C and 9CAP radios. Are these two different radios or do some folks simply drop the "AP" in the designation?</span> the same transmitter with minor variations giving rise to the several labels, refer: . <span style="font-size: x-small">9C Product Manual . Futaba <span class="header02">Product Manuals</span> Alan T. Alan's Hobby, Model & RC FAQ Web Links </span> |
RE: 9C/9CAP
9C 9 channel Computer Radio
A = Aircraft version (ratchet throttle, 3 position switch on right front with a 2 pos on the left, and default of a new aircraft type is ACRO) H = Helicopter version (smooth throttle, the two switches above are swapped, 3 position on left, 2 position on right, default type = HELI) F = FM or more accurately PPM, that means models that are bought with a reciever come with an FM/PPM reciever and model types default to PPM modulation P = PCM. Models bought as a package come with a PCM reciever and modulation defaults to PCM So a 9CHP is a 9 channel heli version with a PCM reciever. Modulation can be changed on a per model basis, and either A or H has the software for both, the only differences are the throttle ratchet and switch position. |
RE: 9C/9CAP
Can the default type be switched from Heli to ACRO?
RE: 9C/9CAP
Probably but you need access to the service menu.
Its no biggie, you just bring up a new model, go to the PARAMETER menu and switch it. |
RE: 9C/9CAP
The other part was the "S". It stands for the Supper version. Better screen, a few more options for programing, but basicly the same as the 9C.
I have one of each, very good radios. Don |
RE: 9C/9CAP
Oh yea, I forgot about the Super....
RE: 9C/9CAP
Hansen Hobby's web site has some accessories for the 9C's that can be really useful when you want do change things around a bit.
