JR 8411 v 8425
Hi All, Just got all my brand new 8411 installed then saw something on the box that didn't seem quite right. They were 8425. Rang my LHS who rang the Importer and was told that there is no difference. Have done a search and can find no specs for the 8425's on there own. Does any one know if there is a difference and can they run on 6 volts? Appreciate any help.
RE: JR 8411 v 8425
Wiggles
Is this what you need?: DS8425 Digital Servo Code: DS8425 Manufacturer: JR Digital standard size servo. Specification: - Digital 11kg (13kg at 6volt) @0.19 (0.15 at 6 volts) seconds over 60 degrees. - Size 34.5 by 19 by 39 mm. - 4.8 & 6 volt operation. - Weight 49grams. - Ball raced output shaft, & metal gear box with sacrificial nylon gear. I made a search on DS8425 and it seems like it´s equal to the DS8411. Regards Thomas Denmark |
RE: JR 8411 v 8425
Thanks Thomas. The info on the back of the box was written in Japanese. It appears that I have been sent either A- A chopper servo or B- A servo that has been tagged for the Asian market. Now if I had put DS in front of 8425 I would of found the info myself. Thanks for the help.
