Futaba Transmitter Questions
I have a few questions about Battery compatibility of Futaba Radios.
I have a 4 year old 6XH Transmitter. I have purchased a Hobbico 1650mah NIMH 9.6v flat 8 cell battery pack for it. WIll this transmitter take this battery without harming it. Also if I upgrade to the 9 channel radio like the CAP can I install that same flat 8 cell pack into it or does it take a square style. Also with the 9 Channel CAP transmitter can I controll my planes with JR and Hitec flight packs installed. How compatable are the crystals between the Futaba transmitter and the JR and Hitec reciever crystals. How much of a frequancy difference can I go when changing crystals on the transmitter. Say it's on #60 can I install a 46 crystal to match a reciver pack in one of my planes. Also On my Futaba Nicad packs how low a mah reading can I get and still use the battery. I am getting 490mah for a 600mah pack after cycling a few times. Is this pack dying. |
RE: Futaba Transmitter Questions
I have a few questions about Battery compatibility of Futaba Radios. I have a 4 year old 6XH Transmitter. I have purchased a Hobbico 1650mah NIMH 9.6v flat 8 cell battery pack for it. WIll this transmitter take this battery without harming it. Also if I upgrade to the 9 channel radio like the CAP can I install that same flat 8 cell pack into it or does it take a square style. I was right -- here is a replacement pack for the 9C/8U series.. http://www2.towerhobbies.com/cgi-bin...?&I=LXBTJ1&P=7 Also with the 9 Channel CAP transmitter can I controll my planes with JR and Hitec flight packs installed. How compatable are the crystals between the Futaba transmitter and the JR and Hitec reciever crystals. If your Hitec receivers are negative shift (Futaba/Hitec) then you can still use them with the 9C... At worst you may need new crystals... How much of a frequancy difference can I go when changing crystals on the transmitter. Say it's on #60 can I install a 46 crystal to match a reciver pack in one of my planes. The 9C uses a frequency module that you can interchange at will. They can safely and legally be swapped around, but they are of course more expensive than a simple crystal... Also On my Futaba Nicad packs how low a mah reading can I get and still use the battery. I am getting 490mah for a 600mah pack after cycling a few times. Is this pack dying. |
I agree with everything Galen writes. Also, you will need a different charger for the higher capacity/nimh batteries.
George |
Two stars to Galen! An exceptionally well written response! And i agree 100% with everything he said! :-D
