12X battery help
The battery on my trusty 12X won't charge. The charger doesn't see the pack and I've tried several different chargers. I switched to Eneloops many years a go and they work great. I went out last weekend and I couldn't charge at all. I still had enough voltage that I flew but I can't charge at all.
I think the PCB board is done, which is why no charger can see the pack. The whole cassette is really hard to find so I'd appreciate any ideas. |
Originally Posted by All Day Dan
(Post 12437864)
There is a small fuse that looks like a resistor on the pcb within the battery case. My guess is that it has blown. This usually happens when you short the charging leads, or plug in a charger with the incorrect polarity. You can temporarily jumper the fuse and be very careful, or find a electronics savy friend to open the battery and replace it for you. I sold all my 12X stuff, and no longer have the parts. Thanks!
