Restoring a 1984 famous Mitsubishi pajero with problems
Hi all
I'm a novice at repairing these cars but I found this one in my loft from when i was a kid my grandad owned it and gave it to me Any way the issue I have steering but no drive the motor is fine as I have tested it and I have also tested the receiver buy moving the channels of the steering both work fine. The motor does not make any noise or do anything when powered on it seems like no power is getting the motor. The servo for the drive moves as it should to the points but no power goes to the motor The battery is fine as I've tested it in another tamiya Ford focus. Any help as I'm pretty stumped Thanks |
is the msc wired correctly with the ground on the same terminal as the live this is an old msc from the 80s if that helps
im getting some smoking from the cable seems like the ground wire is getting very hot and looking at my focus the ground is on the middle round pin i cant upload a pic as i havent posted enough yet |
