servo twitchs?
i have 537's in my mustang and when i have my plane and radio on the ail servos twitch, it flys ok it just twitchs when im starting the plane. is this normal? what would cause this? thanks Larry
RE: servo twitchs?
Your rx is likely picking up the electrical noise from your starter and/or glow igniter. As long as the twitching is only evident while starting you'll be fine.
Might not be a bad idea to do an engine-running range test, though. |
RE: servo twitchs?
While this may not be normal, it is common.
I would not worry. ORIGINAL: flyfree69 i have 537's in my mustang and when i have my plane and radio on the ail servos twitch, it flys ok it just twitchs when im starting the plane. is this normal? what would cause this? thanks Larry |
RE: servo twitchs?
Does it only happen on a freshly charged battery? If so, I get that too. It goes away pretty quick.
RE: servo twitchs?
6V's fresh off a charge jitter a bit...
I say you have metal on metal somewhere- Is this just during start-up? Hey Hawker: Hows the family? Hope all is well james |
RE: servo twitchs?
HEY RAZOR,,,, hows your f-4 flying? it was on a fresh charge,the servos are new and cant find any metal to metal , the wires are kind of bundled up could that do it? i sold my f-4 phantom to get this mustang and funtana-s im thinking of getting another f-4 (crazy-huh) ill get to work on my funtana and see if get my mind off jets.... my girlfriend told me not to sell my f-4, now i have to listen to ( I TOLD YOU) lol thanks for the help guys Larry:D:D
