SERVO REVERSING
I HAVE 3 AIRPLANES WITH DUAL ELEVATOR SERVOS AND TIRED OF BUYING SERVO REVERSERS. IS THERE ANY WAY TO REVERSE THE SERVO INTERNALLY? I AM CURRENTLEY USING A HITEC ECLIPSE 7 TRANSMITTER I REALISE I CAN PROGRAM MIXES BUT IT DOESENT WORK VERY WELL WHEN YOUR FINE TRIMS WONT AFFECT THE MIXED SERVO. WHAT SHOULD I DO?
RE: SERVO REVERSING
inside the servo you reverse the two leads between PCB and the motor and then reverse the two outer (don't touch the middle wiper lead) leads of the pot. you can do this at the PCB or at the motor/pot itself.
dave |
