Hitec RX with JR TX
I am installing radio components in a plane I haven't flown is a long time. I recently bought a new JR PCM 9X and are a bit concerned using one of my older Hitec Supreme series Receiver (HFD-07RA) with this radio. I switched the radio to PPM and it seems to jitter for a second or two before it settles. Should I be concerned?
PS It does the same with all three of my HFD-07RA Receivers. Thanks |
RE: Hitec RX with JR TX
If the TX is on when you switch on the Rx then a second or two of servo twitch is totally normal as it is with many radios.
Assuming that model # of the supreme is the positive shift version then there should be no issues. John |
