5945 for 5925
Looking to trade 2 hitec HS5925's for HS5945's
RE: 5945 for 5925
Have you thought about just buying the 945 gearsets and installing them. You can allways go back to the 925 gears later to sell them etc. I have not put 945 gearsets in 925's but I have put 645's in 625's. Im pretty sure that it will work but you may want to verify it with hitec
RE: 5945 for 5925
Is the gears really the only difference?
RE: 5945 for 5925
smallfly,
I called hitec and sure enough the only difference is the gears! in fact the HS5945 uses the same gears as the HS945 The gear sets are $16 at http://www.balsapr.com/catalog/Servo...ductId=S743259 Thanks for the info! |
