*Airtronics VG6000 flap trouble*
I have flaperons turned on with Lt wing channel 2 and Rt wing channel 6 and all control surfaces work properly except the flaps. When you turn on the flaps they go down and not up. When I reverse the flaps, both ailerons go up and when you turn on the flaps, the right one goes up and the left one goes down. Any ideas???
RE: *Airtronics VG6000 flap trouble*
Sorry...I meant to say that the flaps go up and not down as they should.
Which side of the servo do you have the control rods hooked to? I think both control rods have to be hooked into the outside(wing tip side) of the servo arm...
Thank's for the help but I got it solved. I had to reverse channel 2 and 6 on the receiver and then reverse the flaperons.
