PLEASE HELP........ RX issues!
Ok I have Hitec digitals on a 7c setup for a Dave Patrick Edge. When the servos are on the rx that same with the 7c (fp-r127df) the left ailerons go crazy. I have tried 3 different futaba 127's I have from all my other planes. Now when I plug in my old FP-R128DF to that plane it works like a charm. No glitches, and no jumping... Can this be from BEC that I have read about online? Just seems funny the older RX works perfect. BTW I am running 1-HS5245mg and 1-HS5945mg one each aileron. On Heavy duty Y harnesses. Even with no Y harness the servos are doing it on the pack if ran by themselves. The funny part is that its only the flaperon channel doing it even if I use 5,6, and 7. PLEASE HELP ME!
RE: PLEASE HELP........ RX issues!
Okay need more information. You mentioned a BEC as in battery eliminator circuit. So is this plane an electric? If so whose BEC? What settings? If not what are you using for a battery pack 4.8 or 6.0 volts.
If you tried 3 futaba 127's did you try another transmitter other than the 7C? Perhaps the 7C's transmitted servo signal is slightly off timing for the flaperon mix? John EDIT -> It doesn't sound like the servos if it only happens with the flaperon mix. |
Another option to try is to clear that models memory and start fresh. Sometimes we program some in unintended weird mixes. :)
John |
