throttle servo in reverse?
Hey people!
As you can tell I'm a newbie so this may be a stupid question, Have a Hitec Tx and had to buy a new hitec reciever. After gettting everything together the steering worked fine but the throttle wide open! Tried turning off & on a few times to see if that would help. No go. The servos are futaba. Cant figure out. Any suggestions would be greatly appreciated Thankx P.S. This is on a RC-10Gt if that helps. |
RE: throttle servo in reverse?
Go to your Tx manual and refer to the servo reverse procedure for that channel.
On the TX change the servo direction for the throttle
Yes. reverese it at the TX...
it is confusing, but different brand servos move in different directions... when you are first starting out, it is a bit confusing (been there, done that!) But later on, with more advanced planes, you can use this to your advantage (ie: multiple servos for elevator, etc. etc.) |
