Throttle mix on 9C
I was wanting to try a throttle mix/curve on a 9C. It would be bascally for hovering, but I am not quite sure what type of curve I need to set up. I know the the curve should relatively flat in the hover range. Any tips would be appreciated.
RE: Throttle mix on 9C
heli? aircraft?
Point mix and make 2-4 relatively flat.
Throttle to throttle with no offset |
