How much for service
After losing my four star 3 weeks ago and not being able to find it, I was about to give up on it completely, but this morning I went looking for it 1 last time and found it in quite a few pieces. the airframe is completely trashed, but the engine (os 46fx) is fine. 3 of the four servos appear to be fine, but the reciever (airtronics 92777Z) is not responding properly at all. The servos twitch and glitch and do not respond to stick inputs. I replaced the crystal with an identical crystal with the same results. The case is unscratched and appears to be in perfect condition. I am guessing the rain was not kind to the electronics. So to make a short story long would it be worth it to send it to Airtronics for service and if so how much do you think it might cost? $$ is tight so I am trying to figure out if it is worth it to be repaired or just replace it when I save up a little bit of $$.
Thx! |
RE: How much for service
try http://www.radiosouthrc.com I have had excellent results in all of my dealings with them. The owner is actually the AMA District V VP now.
