TX BATTERY LIFE TIME?
I have a Airtronics 6000 Sport Version, my TX batteries ran out of juice in less them 3 minutes flying time, prior to this it been charging for 14 hours. Tried another battery and the same problem happen. Has anyone had the same experience with this radio?
DMENACE |
RE: TX BATTERY LIFE TIME?
To many possibilities to say what is wrong for sure. First, remove the battery from the transmitter and cycle it on a known good charger. That will tell you whether or not it is a bad battery. If it cycles properly, then your transmitter may be at fault, if not then you know it is most probably a bad battery. After charging the battery, check the voltage of each cell, you can do this by using a sharp pointed probe to punch through the insulation around each cell and measure voltage to see of one or more of them are bad.
