Servo Tester
Hi you ! I need help to homebuild a servo tester to check some unlabeled second hand multiplex. Thanks for any help. IGOS R/C |
RE: Servo Tester
Hi you ! In time. The tester is just to verify the torque force. Sorry. IGOS R/C |
RE: Servo Tester
What aout using a digital fishing scale?
RE: Servo Tester
Use a one inch arm and fishing weights tied to a lead. Ounces is ounces... The one inch arm is important.
Most standard size servos are at least 48 oz-in. Torque specified. 48/16 is 3lbs. |
RE: Servo Tester
Hi JNorton and Mglavin !! Thank you very much for your hints. I will fit the servos which I intend to check on a 1/8" ply, use a 1" arm, use fishing pre weighted, hang up everything and run the test. That's all. Thanks again. IGOS R/C |
RE: Servo Tester
IGOS R/C,
Make a pointer on the end of the 1" arm and put a degree wheel or a protractor behind the pointer. Then you can tell what type of accuracy you are getting relative to the weight. John |
RE: Servo Tester
Thanks again John.
IGOS R/C |
RE: Servo Tester
Instead of an arm use a 1"wheel attached to the top of an arm. Then you don't have to correct for the geometry of the arm. Also a dial indicator is much better than a pointer. Just attach it to the wheel with a string. A cheap dial indicator is accurate to .001 in.
RE: Servo Tester
Hi ! Thanks for your input Dirtybirdi. IGOS R/C __________________________________________________ ____________________ Even my shelf queen beauty suffered a crash due to a screw failure. All planes crash. |
