Is this silly?
Maybe it's a silly idea. Bordering on nit-picking maybe. Why don't servo designers find a better place to put the wire entry so that servos are easier to install? Are we to hung up on a traditional design?
RE: Is this silly?
No the wire has to come out between the pieces of the case or else it would have to be put through a hole in the bottom and then you would have to un solder the wires everytime you wanted to service the servo The entire electronics can be built seperately and then the servo can be assembled without any soldering
RE: Is this silly?
No the wire has to come out between the pieces of the case or else it would have to be put through a hole in the bottom |
RE: Is this silly?
Thanks Crater,
My thoughts exactly. Thinking outside of the box. It isn't rocket science to figure out a better way for a wire to exit something. Heck, the new Hitec titanium geared servos even have some alternate way of mounting them. Something on the bottom of the case I believe. This proves the molds can be changed. :D |
RE: Is this silly?
I agree. I think it would be a good idea for servo manufactures to put different cutouts in the servo case so you can move the wire exit point if you want to.
RE: Is this silly?
I just wish Futaba would get rid of the keys on their servo connectors so you could use them with other receivers without whittling the stupid thing off!![:@]
RE: Is this silly?
ORIGINAL: SitNFly I just wish Futaba would get rid of the keys on their servo connectors so you could use them with other receivers without whittling the stupid thing off!![:@] Safe Flying! |
RE: Is this silly?
I'll have to agree with SitNFly. Whittling those things off is a ridiculous necessity these days. People mix and match brands during a setup. Those things suck.
RE: Is this silly?
ORIGINAL: SitNFly I just wish Futaba would get rid of the keys on their servo connectors so you could use them with other receivers without whittling the stupid thing off!![:@] That key, or the lack thereof, is exactly why I don't like Hitec servos. I have made the mistake of plugging the servo in backward and not noticing until the wing is on and have to take it back off to correct the problem. I think all of the other manufacturers should add the key to prevent incorrect installation. So there you have it...2 totally different fixes for the same problem. |
RE: Is this silly?
If all manf. added the tab, new stuff wouldn't work with old stuff. Remove the tab. And move the wire entry.
