Futaba 9Z questions
Hello,
I just have 2 questions regarding my 9Z. I looked on futabas FAQ page and couldnt find anything. (1) I need to program the radio so that when I put the landing gear down, I get 6 clicks of down elevator with it. Anyone know how to do this?? (2) I have 2 JR 3301 servos, one for each elevator. If I plug them into 2 separate channels, they match up at the top of movement and at the centerpoint. However, in between one servo moves faster than the other then it catches up right before full travel. I put them on a Y harness and they work great. Anyone know what the prob is?? Thanks, Mike |
RE: Futaba 9Z questions
1) Two ways to kill that bird I can think of off the top of my head. You can use an offset mix slaved to the same switch you use for gear. OR, you can set up a landing condition where the trim is preset where you want.
2) Check your setup mixes etc closely. Are you using a PMX to drive the servo's or are you using the Ailevator mix? |
