Futaba 9CAF
I was curious to see if anyone has had any major problems with the 9C radio. I bought mine in April 05, and in Jun I had to return it for a trim pot to be replaced. Now I am having the same problem along with other mixing problems. Lost one of my planes on Thursday for no apperant reason but today the problems started showing up which grounded my planes.
RE: Futaba 9CAF
I have on.
What problems are you seeing? I haven't had any with mine. Some of the mixing and the links of mixes are not consistant within the 9C. I call it a bug, Futaba says it is a programing priority. Just remember that if you are having problems with links in the Pmix modes, then it is the order in which you set up your Pmixes that may be causing your problems |
