"older" Airtronics servos
I have a Vangaurd radio with the older style servos that I would like to use in an electric plane using an ESC device. What wires do I need to switch to make this wire.
Use the pin out table Thomas gave you a link to, if and when you find your wire colors are not those shown, look closely at how the plastic and ribs are in the picture and you will see the two wires that need to be switched.
